SignUp Now!stock to light mods - AC CR44TS gapped @ .035 or autolite 24
if you are running around 12.50 or so with boost at around 20-22psi i go with
AC CR43TS gapped at around .032 - .035 or autolite 23
if you are faster than that with more than 22psi i've heard people have good luck with the AC CR42TS with a gap of .032
Can someone explain the difference in gapping in layman's terms, for instance if I'm running 25lbs of boost what will the difference be between a .035 and a .032 gap...thanks
NGK UR5's here, gapped @ .032, the car ran horrible at any higher boost than 22 with them gapped at .035.
Have tried AC's, Bosch, & Autolites, seem to have the best luck with NGKs.
Hey guys what is the best spark plugs for our cars and what do you have them gaped at ? thanks
