speed sensor and oil pressure sensor
midnight rider
0riginal owner 1987 GN
Im looking for speedometer speed sensor in tranny
I have VDO guages but im pretty sure the stock or aftermarket ones work fine
shipped to VT 05463
the vdo oil sender needs to be specific for your vdo gauge .
the speed sensor stock is behind the dash , theres an optic pickup mounted behind the stock analog speedometer and its connected to a vss buffer (little rectangular green box) mounted to the left of the radio under dash
if you have a vdo spedometer the vss sender youll need is aftermarket. caspersperformance.com has the inline sensor and the buffer, youll need both and sensor installs inline either at the cable joint under the hood by the brake booster or can mount at the trans.
