I'm setting up a sensor to give me driveshaft speed in my datalogs.
I'm running a TH400 transmission and since output shaft speed is the same as driveshaft speed I'm simply going to install a reluctor on the output shaft of the transmission and plug an electronic speed sensor in where the speedo housing normally is.
This GM sensor is a two wire sensor.
If anyone is in need of installing an electronic speed sensor on a TH400, these are the GM part numbers.
Sensor 8655315
Reluctor 8655291
Connector 12085498
Sensor 8655315
Reluctor 8655291
Connector 12085498
