Speedometer calibration help needed
Sleeper
I need some help with recalibrating my speedometer.
I did a diff gear change from 3.00 to 3.25 (I know :) please read sig) and my speedo is reading about 5 mph low. I have a 11 tooth (orange) drive gear and a 31tooth driven gear.
If I use the formula:
#of teeth on old gear x new gear ratio / old gear ratio =# of teeth on new gear
(31 x 3.25) / 3.00=
100.75/ 3.00 = 33.58
Since thay don't make a 33.58 tooth driven gear, what combo of driven and drive gears should I use?
Paul
Thanks Greg :)
Help???
Something ain't quite right here???? :confused:
If I use the formula on the TCI page to calculate TR/M it does not match the Dunlop spec sheet figure for revs per mile of 899?
Tire Rev. per Mile = 20168 /Tire Diameter (inches)
873.07 = 20168/23.1
Plugging both numbers into the other formula...
# Driven Teeth=
# Drive Teeth X Axle Ratio X Tire Rev. per Mile/1001
11 x 3.25 x 873.07/1001=31.28 TCI
11 x 3.25 x 899/1001=32.11 Dunlop
According to the TCI #'s and auto calculator I have the right driven gear in it now but I know it is 5 mph low.
They also list a 35 tooth driven gear for the 200-4R tranny but everybody is telling me that it does not exist??? :confused:
FWIW. Tire is a Dunlop 205/50ZR15 that has a section width of 8.4" and a tire dia of 23.1
Paul
My old GM 200-4R parts book lists part number 25522477 as being a 35T-orange gear for a 1988 Caprice w/ 2.56 rear. That part number is probably no good anymore but perhaps you can find a cross reference.
The formula is figured as follows:
5280 ft/mi = 63360 in/mi
tire circumference = pi x diameter = 3.14159 x d
tire rev/mi = (rev/tire circumference in) x 63360 in/mi = (1/3.14159 x d) x 63360 in/mi = (63360/3.14159)/d = 20168/d
Either they have some creative math going or they forgot to inflate the tire when they checked the revs/mile. :p
