SignUp Now!I'm waiting on a response from one of my dirt track friends with the info on an off the shelf ball joint that's longer. I know they're out there and the dirt track guys have used them before without reaming the holes out in the steering knuckles. I'll post up the info when I get it from him.
What I have found out so far is that the Howe's bend really easily according to the dirt track guys. You can also replace the stud if you need to and change the height of it to change the way it will work.
AFCO are the prefered ball joint though.
As far as an off the shelf ball joint goes you will need to ream the upper out to use the 78-86 chevy 1/2 ton upper ball joint but the lower is off the late 80's early 90's big GM cars like the caprice or Impalla. It is a direct swap for the lowers but only changes the spindle height by 3/8".
How much height do you get out of the Afco or Proforged?
By using the off the shelf parts you will gain 7/8" and by going with after market racing parts you can gain as much as 1.25". Most will gain a 1" difference off the after market ones Irv.
