splicing air temp sensor wires
Larry
I am moving the out side air temp sensor to the plenum. Can I just splice the wires to extend to the lengh required, or is that some sort or special wire you shouldn't cut into?? Thanks Larry:confused:
Larry, i'd solder and heat shrink your connections . It's alot better than using butt connestors. I think i saw somebody sells an extension harness. You might check with Casper's.
