My only gripe was that I had to drill extra holes to use the stock transmission mount. I used a polyurethane mount at first and it had a ton of vibration inside the car. The stock setup has a rubber transmission mount and rubber bushings where the crossmember bolts to the frame and cuts all the engine vibration out. You will notice a little more when you switch.
