ok so i found out the b body spindle swap drops the car 1" in the front so i need some front springs that has 0-0.5" drop but is about 50% stiffer then stock and need rear springs that does 1-1.5" drop again around 50% stiffer then stock this car will be several 100 pounds dont know if i can just stay with the springs mentioned above i think a spring 50% stiffer then stock should make the car handle better with out making it like my vw which has coil overs and is pretty stiff and should hopefully match up with the bilstein shocks
