Sprinkler Pro’s: Step on in. Need help.
Jerryl
Tall Unvaccinated Chinese Guy
This started suddenly. Matter of fact, it ran earlier this week.
Trying to adjust the spray pattern running it manually, but "no go". :mad:
All programming functions work, just won’t run the sprinklers. Specifically, whether running it in auto or manual, the “clock” displays on the unit, whereas before, the sprinkler/time used to display.
Weird thing is, you can select a single station and time just fine, when turning it to “Run mode”, it displays the clock and nothing happens. The output wire gives a brief voltage spike, but that’s it.
Hunter SRC 600i – Installed 6/2001
Rain sensor appears fine (?)
Power supply /battery are good.
Completely reset the system.
Anyone know about this junk? :confused:
