streetknight
DCVING
- May 26, 2001
I'm running a PAC alky kit. The car has upgraded pump, adj. reg, and good exhaust system. Other than that it's stock. I had the sputtering problem, put on a new coil pack and it went away. This was with boost in the 20# range. I've also been chasing high BLM's issues and they were fixed with new injectors.
Before the car had stock injectors, now it has 50lb.
Now the boost is set at 24psi with the 50lb injectors and Turbo Tweak chip. I had the fuel pressure at 42psi with the line off and the blue knob on the PAC kit in the middle. It sputtered and broke up badly at WOT. I figured too much fuel and reduced the FP to 39psi with the line off. NO CHANGE. I then backed the blue knob on the alky from the 12 0'clock position to the 10 o'clock position. On this pass the sputtering was pretty much all gone. The o2's were 850-860 in first and second gear and 790-800 in 3rd gear. Injector duty cycle was around 70%.
Any ideas?
Any ideas?
