RFM87'GrandNational
- May 15, 2012
im wondering if its a fuel presure problem or a boost problem only happen once n a while . a sputering poping feeling while rolling into the throttel engine temp was around 175 degrees turbo boost seems a little laggy . only shows up once in a while other days its running perfect. its kinda fluky. ive 97 premium gas. it sat for about 2 years with a start up twice a month but it did have a good 6 months with a dead battery but have been cruzing around in it lately this problem occurred in the past 3 months after winter. i would like some advice or suggestion on what could be the problem. i have alot of work to the car larger turbo, fuel pump with lager wire with regulator. larger throttle body custom air intake headers with a 3 1/2 inch down pipe in to duels everything but bigger fuel injectors im wondering if thats the problem. any advice would be helpful! Thanks
			 I give up Chuck........
