They look nice (I guess).... what's the chance that they actually perform better? I guess I'm skeptical that those aftermarket (aluminum? or SS?) calipers had the engineering R&D (and corporate liability oversite) that the OEM pieces had regarding actual performance.... any subjective (or objective) comments on how they actually work... like a couple repeat, triple-digit haul-downs? Proper F/R balance?
Are those the stock pins that are holding them on? They appear to be... I would advise using some good anti-seize on those threads... SS or AL+MolySteel+extreme heat= SEIZED
Spacers suck...
Not hatin', just commentin' and curious... :smile:
Well, I overhauled the front brakes less than 2 years ago with all OE parts and the calipers were already sticking and driving me nuts with all the squealing. Didn't matter what pads I used or how much I gooped things up with anti-squeel....they squealed.
You'd be surprised....most of the design engineers working for these aftermarket companies are former big 3 designers, and the big 3 also source from many of these aftermarket companies for their own "high performance" catalog items.
For example...Edelbrock is the source for all the GMPP heads and intakes used on the GMPP crate motors.
I put the same dual piston SSBC brakes on the front of my 68 Camaro with their 10.5" rotors and it made a world of difference in stopping power. Worked so god I upgraded the rear brakes with SSBC 11.25" rotors and single piston calipers. I used an adjustable proportioning valve in that set up so i was able to dial in the F/R bias to fit my needs. Works great!
The calipers I installed on the GN are also dual piston and those and the rotors and the rest of the parts are all American made (I'm done with the chinese rotors and hardware kits sold over the counter). The pins came with the caliper set. Same size as stock pins, but I'm pretty sure SSBC sources them, themselves.
The braided lines are Global West.
I used some good Timken wheel bearings too.
In driving around yesterday, yes, the peddle has a much better feel and the car definitely slows its roll much faster. I've seen magazine tests with these brakes on first gen Camaro's and they improve the stopping distance by several feet and then some, which is all the difference in the world if you're coming in hot behind another vehicle at a light.
