SignUp Now!8445 are stock prod head , not shure what you mean stage 1 head, some vendors call there ported with egr filled with lead stage 1 .need more info on your stage ?
The actual StageI casting number is 6293. The 8445 and the 6293 are essentially the same head. Some production 6293 have the bridged end water ports, too. All StageI heads have the bridged water ports, and no EGR holes drilled. The cavity is there, just not finished drilled. Most head porters fill the EGR cavity all the way to the manifold flange with aluminum, and then machine flat.
(disclaimer: some other StageI castings "may" have been released by GM, but I'm pretty sure the above info is accurate. I have personally had all of the above heads on my bench at one point or another over the last 21 years.)
The photo you attached appears to be a set of 8445 heads used for oil testing in from the mid 1980's through late 1990's. They had the EGR and heat crossover ports deleted. They are very hard to find because GM never meant for them to be released to the public.
Buick moved on to the Stage II heads and the specs and tooling for the Stage I's were sold to M&A who cast them in aluminum, and then later they sold everything to TA Performance who improved them a lot and is now selling them.
This is not true at all. Buick destroyed all the Stage1A tooling and info. The M&A head was designed by Ted at M&A with the help of Kenny Duttweiler. The tooling would not have worked for aluminum anyway.
Mike
