Stage 2 4.1 Short Block Assembly
jporte12459
Stage 2 on center block. New billet steel main cap #2 #3. (Block can be used with wet or dry sump)
BMS crankshaft 3.625 Standard size
Rod and main
Carrillo Rod 6.5
JE pistons 9 to 1
Rings set speed pro total seal
Hydraulic roller cam
Oil pan with pickup
NEW
JE pistons set
Ring set speed pro total seal
Timing chain set. double row
Front timing cover
High volume oil pump set
Ring set
Cam bearing
Rod & main bearings
JW Flywheel
Balance
Head Studs
Heads gasket set
Freeze plug set
Short block assembled by professional engine builder (Progressive Racing Engine)
Machine work on the block was done by the same company.
Front timing cover has been modified to accommodate the brackets and pullies of an 87 Grand National.
***Short Block: $8,000
Is this the block that was at Progressive racing engines in opalocka ?
If it is it not an on center rather an offcenter no on center had oiling provisions there all dry sump .Laz
