stage 2 heads on 109 block?
The heads will bolt on, but without the extra head bolts, the benefits will be very little. You will be gasket limited like the stock heads.
And the stock type cam won't work with SII heads either.
Your post started me thinking about S2 heads on a stock block for TSM class racing.......I went and checked their rules......no Stage 2 heads allowed, darn.
That might have been fun!!!
Well it looks like LAz is making rwhp 700 hp on stock heads and it hold together, makes you wonder......about those extra bolts
In addition you would have to set them up for small valves to fight the shrouding.
there's people on the board that make as much power with 300ci. T he only thing keeping these big inch builders in business is the class rules (no turbo's) or they would die like the dinosaur.
Also you can't take them shopping, or pass a gas pump at todays gas prices :eek:
