- May 28, 2001
Sorry turbobitt I thought you were Norbs. My apologies.
SignUp Now!Sorry turbobitt I thought you were Norbs. My apologies.
No worries, long winter.Sorry turbobitt I thought you were Norbs. My apologies.
I drove Terry Houston's Stage 2 headed street car. It was a 4.1, 3.4 stroke, 8:1 compression, stage 2 heads, 76 Q-trim .85 3 bolt (old 11 blade Q), TH400 with a Precision converter probably a 0 pump, 218/218 solid roller. It had as much bottom end if not more than my old 245" 109. It spooled the 76 way faster and started making boost lower rpm. Now at 26psi, it went 10.20@136, where my old 109 went 9.86@138 on 23psi. At the time we both had 76GTQ turbos and I was running a 0 pump Vigilante 5disc in a 2004r.
That was with an on center pos housing and converter slip way higher than we'd ever see today too.I agree on Your assessment but with this exception, when I had an old t-netics 76mm 11 blade Q-trim with .96 A/R I was able to spool it very fast as well. But I was also able to get down in the 9.80's about 12 years ago at about 20 psi boost on a bad tune and on DOT's. This was with the same 242 cam I was running for a while. I never pushed that combo to its full potential.
AG
Once I find my HP book, Ill put the math to show the rpm where the port dimensions , come to life..
I agree with you but, I'm still dealing with family issues, and we have seen a recovery in my dads condition, which is good news!Who cares about math. Show us the dyno results !!!!!
AG.
I know, Believe me when I say I'm just trying to be a positive motivator. Good to hear about your Dad.I agree with you but, I'm still dealing with family issues, and we have seen a recovery in my dads condition, which is good news!
What's the port area of an unported stage 2 head? That calculation would no doubt drop the rpm peak torque number a bit.
