- Jun 6, 2001
SignUp Now!The alternator needs to move closer in and up to miss the driver's side turbo. I am looking for an alternative mounting system either near the stock location or on the pass. side at the end of the valve cover. I am using P/S and a factory type water pump. Ideally I would like to lose the remote P/S fluid reservoir and use one of these type pumps with a built-in reservoir from Detroit Speed:
and keep using a serpentine belt, somehow.
I am looking for ideas from other stage owners on how you mounted your alternator and power steering (pics) other than the Champion bracket. It looks like the non-A/C early turbo Regals mount the alternator on the pass. side with V-belts to run the P/S, alt. water pump (what year donor car for the brackets?) as a possible alternative. Post what you got.
Mike
I'll take a look at Moroso and see if they still sell the stage 2 stuff, I noticed a set of Moroso stage 2 valve covers on Ebay and I had never seen a set before. What about cog-belt setups like a timing belt? In searching for cog pulleys I came across a couple companies that make some really sweet cog belt setups for, well, you know, SBF, SBC & BBC, the easy crap.My first set is Moroso, they used to make a set of alternator brackets that gave you the option of either side to mount the engine. High on the driver side and low on the passenger side. Moroso used to carry a lot of the oil pans, alt. brackets, belt drives, and pulley's for the stage 2 stuff. I will go thru boxes and boxes and look. After buying so many of these motors you tend to keep the extra small parts that come on them. I bet Mike Booher would have some. You could also go custom, it's just aluminum and proper spacing. I doubt if there are any stage 2 guys out there that doesn't have several v- belt mandrels, gilmer drives and brackets that they didnt need just laying around. Hopefully you will get a good response. I dont have the champion set up on either of my twin turbo motors. I will try to get you some pics also.
I'll keep that one in mind Mike, I first want to see all my options before I jump.Since I'm putting power steering back on my car, I've removed my alternator mount I made. I could reverse the bracket on the head and the tensioner and make it work on the passenger side.
If you want it, I'll trade you for some of the power steering parts you won't be using anymore.
