Stage II parts
turbobitt
3.59 stroke BMS crank. .010/.010 undersize. Crank was removed from a running engine and polished. Measurments are...
Main pin,
1 - 2.4893
2 - 2.4893
3 - 2.4892
4 - 2.4889
Rod Pin ,
1 - 2.2381
2 - 2.2385
3 - 2.2385
4 - 2.2385
5 - 2.2384
6 - 2.2384
$650 Plus shipping
Also, set of used Stage II JE pistons for,
4.00" bore
3.625 stroke
6.5" rod
.927" pin
Double pin oilers
1.2mm / 1.5mm / 3mm ring grooves
Valve reliefs for stage II head
8.5:1 compression
Pins not included
$350 plus shipping
Modified Duttweiler oil pump cover for external oiling. Modified with extra oil feeds and steel wear plate. Can be used on standard or deep pocket/long gear oil pump covers.
$200 plus shipping
Please E-mail Turbobitt@comcast.net or PM if interested
Allan G.
how much for the piston pins? what hp are they rated for? Need any parts in trade? interested in the duttweiller pump and maybe the crank.
Pump sold
Crank reduced to $600
Pistons reduced to $300
Allan G.
Yes, I'm keeping the pins. I'm using them in my new pistons.
Allan G.
The crank sounds like a good deal. Has it had any previous weld repairs? It looks to be wide journal correct?
THX
Neal
Don't think it has any weld repairs. My crank machinest is very good at identifying such repairs and never mentioned to me that this was ever done. I bought this used and it was already ground. I just had it ballances to my rotating assembly and ran it for the last 8 years(mostly street driving).It is a wide journal crank.
Allan G.
