bob86gn
Senior Member
- May 24, 2001
Well, I started the swap of my Stage Jr heads from Dave Chase to Aluminum GN1 heads today. The Stage Jrs went easy low 12/high 11 without crazy boost. Once I opened up the motor I found the head gasket on #3 was blown out the top towards the intake manifold. That probably explains my oil blowing out the breathers under boost. I will start the bolt up of the Champions tomorrow but man I am a little nervous about the Champions sealing with stock gaskets and living a long life without breaking.
I know Warpspeed has about 40K on his without any problems, anyone else had GOOD luck with these heads?
