stage2 hi rev kit
I will venture a guess that it will with a little modification(shorten one side)
block and lifter locations, deck height etc are the same. stage 2 heads the pushrods are leaning towards the front of the block on DR side and to back on Pass side. I think that production heads the rods are pretty much straight up. If that is the case shorten one end on each side and it will work perfectly. mike
You might have a problem running the Isky lifters that are used with the Rev kit. That lifter will uncover the oil galley on a stock block. Bushing the lifter bores would solve that problem.
DR
DR
Unless you run the new Crower solid rollers, that have a shielded roller. TA Performance sells 'em.
Billy T.
gnxtc2@aol.com
