I rebuilt my motor with LOTS of goodies well after I installed it I had a massive oil burning problem. So after trying everything I pulled it to see what happened. At first I thought it was my rings so I brought it to my machine shop (who is very reputable and knows these motors) and he tore it down. Turns out everything was perfrect on it so it was nothing I had done. The leakdown and rings were perfect. Well I had put the revolution X roller cam kit from Full Throttle in when I oringinally built the motor with a 210/215 duration and a .516 lift and apparently it was too much for my stock valves. I had alot of work done to these stock heads fully ported and polished when I had the original machine work done along with titanium valve seats and positive seals. So my guy called me and told me that the valves were the problem and that the lift was so big it was causing the valves to seep a little bit of oil and than burn it up in the combustion chamber. So he is going to enlarge the bowls a bit more and put bigger stainless valves in. Anyone had this problem before? Anyone used stainless valves? What are the advantages? Disadvantages? I would assume that they flow better and the obvious more surface area to allow more mixture in and exhaust out along with the fact they will resist corrosion big time. Any input? Thanks in advance
-Andrew
-Andrew
