standard size forged pistons?
gteatr6
Just pulled my 109 motor apart and the bores are still standard. Does anyone make standard size forged pistons? Should I just reuse the stock pistons or over bore .020? I'm looking to run low 11 area, but mainly will street drive it.
I would reuse the pistons if in good shape. SAVE THE MONEY for another go fast part.
There is no way you can use a standard size forged piston in a used 109 block. :mad:
After it is cleaned and honed, you will have way too much clearance for the forged piston. I have NEVER seen this possible in hundreds of 109 rebuilds.
Even the stock cast pistons would probably be too loose after a hone job? :confused:
I'm at 3.799 to 3.8005 for my bore sizes. I can still see the cross hatch pattern in the cylinders. Motor is out of my 42,000 mile Gn I'm doing a frame off on. To me, it looks like I can just have the crank polished and ball hone the cylinders. I have no ridge on top either. I opened the motor just to verify what I'm dealing with.
If you already decided you were going to re-use the 25 year-old stock pistons which are worn, in cylinders that are also worn, why the hell did you ask for an opinion here? :confused:
A true 42k mile engine I would have never opened up, unless it was hurt. Now a 142k would be a different story. What did your bearings look like?
Take it easy Nick, Jeeeezz.
I'm putting my original 109 back together with the original pistons and rods also.
I took great pains to get the bores and pistons measured up, and all are still WELL within original factory specs. This is for a stock rebuild btw.
I've rebuilt just a few engines........... and I would never use a ball hone on anything!! Those things have there place, but not in your cylinder bores!! You will never see ball hones in any competent machine shop. They will destroy your finish. Goodson sells a soft brush hone that will break the glaze and will not destroy your bore finish. I highly recommend this approach over using a ball hone!
It sounds like you have already measured for taper and out of round in each cylinder. If you have less that .001" taper and out of round, you are lucky and in good condition.
The stock pistons are heavy, but extremely strong.........and you already paid for them!!! If you are not building a race engine, reusing the stock pistons is an option. If you can find a media blaster who uses "Soda", have them "Soda Blasted" clean. The soda dissolves with water and is very friendly to the aluminum surfaces. You won't even need to remove the pistons from the con rods if you use this method. Even if you have a bit too much clearance, you can have the piston skirts coated and that will take up the excessive clearance.
A nice set of Total Seal file fit rings and some good cleaning will put you back in the game!!
UF-250 <BR />Ultrafinish Soft Hone 3in Dia. | Item #UF-250. | Goodson Tools & Supplies for Engine Builders
I have only removed number one main cap and the bearing looks great. I had doubts about the motor's miles and that is why I opened it. I think I am going to build another one and leave this one alone since I did not remove the pistons and crank, I'll just clean it up and put it back together. I will then hide it in my garage since it is a numbers matching block to my car.
If you're refering to me, I didn't mention ball hones anywhere. I woiuldn't use them either. I don't hone, I leave that to a professional.
And yes, the out of round and taper were all well within spec, BEFORE and AFTER a light hone was done. Even with 100,000+ miles.
But it's my numbers matching block and was never abused.
Dave,
You're good........some one else made reference to using a ball hone. Those things will trash a cylinder wall.
Honing is both an art and a science that is best left to professionals with experience and the right equipment.
I just tore down a lower mile 87 longblock & after all the measuring the machine shop said for stockish type HP just new rings & go but for 600 HP we used custom 5 thous over CP pistons I got from Nick. They assemble & warranty it so I spent the extra $$ with K-1 rods etc etc. I have never blown up one of their motors except head gaskets. So it could have just gone back together on a budget cruiser build easily but not for 26lbs plus boost!
I would never take a good motor 20 over tho! 5-10 max.
