Sal Lubrano
- Apr 26, 2002
I started my GN today and the outside temp is 30 degrees F. My idle pressure was 70 psi and climbs as I brought the rpms up. The car has an adjustable oil pressure regulator. After the car comes up to temp WOT pressure is 60 psi. My question is 70psi too high for a cold idle pressure and as I drive it goes up from there . As long as I keep it under 2000 rpms it will not go over 80psi. Should I lower the relief set point?
