My car was hard to start if I immediately tried to start it after I shut it off. I usually leave it parked for several hours at a time anyway, so this was usually not a problem.
I thought that I had starter heat soak. I replaced my starter with a mini starter that I wrapped in a heat sheild.
Well, I still have the same problem. My car wont start if it is really hot after I drive it. The starter spins for one or two cycles, then all of my power goes dead. If I turn the key off, and then on again, my power comes right back on.
My battery and alternator seem fine.
A while back, I relocated my battery to the trunk. The wire that goes to the starter is a 4 gauge wire. That wire goes to a 200amp fuse. That 200 amp fuse goes to another 4 gauge wire. That wire goes to another 200amp fuse in my trunk. That 200 amp fuse goes to a 4 gauge wire that goes to my battery.
The fuses have been turning from silver to purple when this problem happens. I know it is becuase the battery is throwing massive amounts of juice to my starter. I even blew a fuse a few weeks ago, back when I had the original starter.
This is my theory:
When the starter is hot, it takes more juice to start the car. The extra juice is killing the 200 amp fuses. I supported my theory today (when I got stuck) by bypassing my fuses and running the cable direct. My car started, but only after it cranked for a few extra seconds than it normally does. I then put the fuses back in line.
So, is this just a problem that I will have to live with? Will the car just be hard to start when it is hot? How many amps is the stater pulling when it is having this problem? Should I just use bigger fuses?
I am thinking that I never had this problem before, when the starter was fed right from the battery. I don't mind using bigger fuses, but I don't think that the starter should be acting the way it does.
Could there be another problem? Like the cam sensor or something?
TIA
This is my theory:
TIA
