This has been a 7 month project, and I'm so bummed right now. The motor is now back out of the car, on an engine stand and tore down to the short block.
As I was finishing the car ( by "finishing" I mean I was actually putting water in it and starting the car) I noticed a leak. I ran the car for 3 nights tuning on it before deciding to fix it. I noticed the small (silver dollar sized) puddle of water, raised the car and saw a fitting that looked like it was leaking. Didn't think much about it. Figured I'd fix it later. Didn't seam like a big deal. So, day 3 of running the car and tuning on the fast, it was running pretty good. Real responsive and sounded wicked. I decided to fix that damn leak. Once I had the light on the fitting and got a closer look, I noticed above the fitting, on the block, was a small stream of where water was running down onto the fitting I thought was leaking. That's when it went all down hill......
I just knew that stupid head bolt/gasket was leaking. Figured, seal tabs and a retorque was called for. So, I pulled the header, the rockers and grabbed the torque wrench. I set my light down, then noticed another small line of water on the head leading right to where it was running down the block.....head was cracked. At that exact moment, I felt beat. I felt like the car just bitch slapped me. So the project is on a slight delay....along with my happiness .
I did get a vid you can see of the car running. Gonna put it on YouTube soon.
