Mike T
- May 3, 2013
1400 miles ago I put a set of standard travel morel rollers in my new build and was obsessed with not going over the max .025 recommended for fear of hanging a valve open at higher RPM. Well after initial break in of the motor they rattled a little. I put readjustment off because of tall valve covers and poly mounts in conjunction with flat body mounts making the passengers side a nightmare.
Finally took the bull by the horns and striped it down to do the job and before just randomly adjusting things I double checked that tolerances hadn't changed or that I hadn't adjusted them wrong in the first place. All were very even and took right at 1/2 turn (.025 in my case) to remove preload. Ended up going to a little over 5/8 of a turn past zero on readjustment and the valve train sounds MUCH better. Under just the right conditions I get just a hint of a VERY small tick so I'm thinking of going to 3/4 or possibly a full turn. In all fairness they recommend 5-30 oil and I'm running 20-50 so that could be part of the issue.
