Static Compression Ratio?
ECHO
How much power are you guys making with off the shelf GN1 performance stock stroke 4340 rotating assembly? What are your ETs with boost numbers? I have JE pistons with 29cc dish well already which is like 8.5:1 CR. Will a 14 cc dish well volume with custom pistons be better at a 10:1 CR? My goals are to run in the 10's with 550+ horsepower 99% time on the street.
If you run E85.... go for it!
mid 9s on je .020 8.5CR pistons ,stock stroke forged external balanced , K1 rods , irons .051 cometics, 215/220 roller and TD 1.55 , ... HP around 820 93+alky drive it anywhere
with 10.1 youll need octane all the time so e85 or race fuel only .. no 93
@dvernst has had good results with his at ~9.7:1 using stock crank and rods. It runs much better than was ever expected, hitting 128-129mph with just 22psi boost from a 6266.
I’m converting to E85 120lb injectors, 450 fuel pump and Teflon lines. I will be upgrading to the TurboTweak ECM.
With a 29cc dish (on stock castings) you'll never make any real compression. Even if you hit the head.
14 might be a little too small, and it'll most likely knock you out of any quench range.
When I make my pistons (22cc), I start at .040" off the head and see what I've got. 99% of the time that's when I stop. The only time I have to remove compression height is on the case of very small combustion chambers and stroker cranks.
What you have is more than enough for your goals. No need to spend money just to change pistons
at that power level alot of options,although i am a fan of compression,with those goals you dont need to change from 8.5.
with octane you can run more compression but what you need to understand is higher compression narrows the tuning window,lower compression widens it.more compression drives the turbo easier but with your goals anything would work.
Yep as mr spool said you better be on your game if you start narrowing that tuning window because of higher compression you can get yourself in trouble
