MeanBuicks
Scaring the neighbors!
- May 24, 2001
Do any TR vendors sell these or are they only available direct? I need to rebuild my anti-theft arsenal for another car so I'll start with this.
SignUp Now!MeanBuicks said:Do any TR vendors sell these or are they only available direct? I need to rebuild my anti-theft arsenal for another car so I'll start with this.
1978-1987 Regal -
COLUMN PRO-GARD STEERING COLLAR LOCK
This car guard collar lock, "Column Pro-Gard - Auto Security Device" will
fit any 1984-1987 Regal model with either console or column shifters. It
also fits a wide variety of other GM vehicles, including 1978-1987 Jeeps. A
full listing for other applications appears on the box.
The red, solid steel construction collar guard covers the the steering
column as well as the ignition switch. The lock for this collar is
incorporated into the unit, which makes it easy to use and store.
It1s highly visible, bright red, and comes with two special keys.
As you know, it's important to have as many theft deterrents as possible to
keep your Regal in your possession. This collar guard makes it especially
difficult to break the steering column in your car. We highly recommend this
unit as a visible theft deterrent to use along with some other device that
cuts off the fuel system or ignition. You can never be too safe. Don't wait
until it's too late.
7007 1978-1987 Regal - Column Pro-Gard Steering Collar Lock $51.95
Just playing devil's advocate here because I'm trying to learn but if the OEM piece is plastic and pops off relatively easy to install the collar then is it really any better than the replacement part provided?TurboDave said:They actually have you break the OEM plastic one off (rendering it impossible to put back in place) and replace it with this "cheezy" thin metal one to replace it. It has only two very tiny screws that hold it in place, so it provides NO protection whatsoever.
DR BOOST said:a few years ago we had come across a car in the boneyard with a steadfast collar on it. i tried screwdrivers , pry bars , tire irons , and finally a sledgehammer. the vulnerable areas of the column were still protected.
the steadfast IS the best way to protect the car from being started via the column.
p.s the lil chrome part is only held on with two lil screws because the real protection is a steel ring behind it.
surej
