Yes and Yes! On the hinges, if possible, you'd be better off getting them off a four door G body. Fourdoor doors are much lighter so therefore less wear and tear on those hinges.
The door hinges are NOT interchangable between 2 doors and 4 doors. Also make sure your columns have the same wiper switch(delay or pulse wipers). If not those can be swapped from one column to another. Eric Fisher
Originally posted by turbofish38 The door hinges are NOT interchangable between 2 doors and 4 doors. Also make sure your columns have the same wiper switch(delay or pulse wipers). If not those can be swapped from one column to another. Eric Fisher
Hi John, Not according to the old trusty 44W parts catalog. Since I dont keep the 4 doors and wagons around to look at I couldn't see what the difference might be. Eric
Hi Eric.......when I first got the front door hinges from a four door, I compared them and saw no difference. I used them to replace the hinges on my wife's 87 coupe. Whatever the difference may be, if there is any, it hasn't come to light.
