STEP BY STEP ENGINE REBUILD!
Is the gap between the rocker and shaft supposed to be there? ??
ks
Yep, its normal, the rockers are loaded on the shaft by the pushrods/lifters pushing upwards on the pushrod cup in the rocker on one end, and the valve spring pushing up on the other. They obviously pivot on the bottom of the rocker, that's the fulcrum. It makes me laugh when people remove a stock shaft rocker system from a Buick V-6/V-8 and says " LOOK AT HOW LOOSE THEY ARE" Its cool, your learning:chicken:
It should look like this when your done
I run 21- 25psi in my tta with alky no issues
Head gasket is 9441
On the kit. Give me a few days
Rjc ( pain in the ass to install )
Comedic ( leak when cold )
Oe gm ( if u can find them )
Sent from my SPH-L710 using TurboBuick Mobile mobile app
Just remember better to blow a gasket then to crack a block or crank or !!!
My belief is u need a small weak point cheep to fix
You could just call Champion they will have Cometic and maybe stock
