- May 28, 2001
http://taperformance.com/proddetail.asp?prod=TA_V1705
You will have to order head gaskets seperately. If you dont have one, you will need a good torque wrench.
You will need a double roller timing chain set as well. I would have a look at your front cover. Earl Brown on the board can hook you up with a blueprinted front cover.
Where are you located? You will need a good machine shop to rebuild the block.
