MrScary666
- May 20, 2014
I posted earlier in the week as I thought i blew a HG. After a quick compression test all cylinders are equal psi, my guage may not be accurate as it keeps blowing the hose from the fitting, but read equal psi nonetheless. When i pulled the brand new plugs, they all had equal amounts of oil on them and the electrodes. The problem I had was the oil in the intercooler, UP, and throttle body. I am pretty confident that the factory turbo is the problem allowing oil into the intake system. The passenger header going into the turbo was caked, you couldn't even see the o2 sensor. The car smoked a little after this happened and is running like garbage. HAs anyone seen a HG blow, and allow equal parts of oil into the cylinders like this?
