I have read dozens of posts on this and tried to find the most logical solution, but nothing is working. It just keeps cutting out at high RPM, as in between shifts. Once it shifts, I can roll into the throttle and it pulls fairly well. My scanmaster readings look good, and the FP is set at 42 with line off. IAC at idle is 23 and TPS is at .42 and 4.4. Airflow is at about 240 at WOT. I can tap the MAF while the car is running and it does not flinch. The coil packed ohmed out good, about 12k across the 3 banks. Boost is low at about 12 for now. I have tried adding and reducing fuel and timing through the translator, but makes no difference.  Below is what I have done in the last few months:
New Walbro fuel pump and sender unit from Racetronix
new intake hoses and clamps
rebuilt turbo
replaced all gaskets including head gaskets
new radiator
10.4mm Taylor plug wires
R43TS plugs gapped at .32
New RJC manual boost controller
new caspers cam sensor cap
new turbotweak 5.7 chip
rebuilt turbo
new radiator
