Scottyb : Believe me, you're not the only one confused here ,and yes you're right on both. The voltage does jump when running, it starts at .36 key on engine off and jumps to the proper .44 when it's running. So I'm getting the proper start and end voltages, but not linear to the amount of travel.
Razor and Bob : good idea on the signal wire, I'll have to try that in the morning. I'm pretty sure the wiring in the harness is OK based on the previous testing. I believe that both Sensors came from different sorces, one of them a TR vendor so I'm leaning toward the ECM too. That test tomorrow should tell me for sure. If I have to, I guess I'll be purchasing a ECM from RED REGAL T soon.
I'll also check that the 5V feed stays at 5V for the whole TPS travel range and give the ECM and connectors a shot of contact cleaner while I'm at it.
I'll report back tomorrow what I find. Thanks again!
