87bluenational
- May 8, 2006
Well I have been having some troubles with getting boost at launch and now that I was able to get the car into third gear I was able to find out were the boost is when it shifts from 2nd to 3rd. A hole 6psi. First to second is 5psi and second to third is 6psi. The boost dose not go down but does not climb past that point. We also tested this on a 5 mph start. When we break torqued it we got 3psi and still shifted at 5psi. I did noticed that when we break torqued it the boost got up to 3 but started to go back down as soon as it got to its max, 3psi. I am only running a 2200 stall and i know i will need a larger one but that should not be the reason the turbo starts to spool and then stops. Or is it. It does not look like any exhaust leaks either. No charing on the header or crossover pipe. I am at a lost?????
