Yes there is non magnetic metal filings in the oil, most noticeable sitting on the bottom of the pan. Trying to find the best approach to diagnosing the problem, I did upgrade the torque converter a couple of years ago, was wondering if that could be the issue even though it had the proper clearance from the converter to the fly wheel per instructions.
Metal filings are silver in color. No I haven't checked crank end play was waiting to find out if that could be a possibility. Oil pressure seems to be fine but will double check to be sure.
Thanks for your reply.
Yes I still have the factory cam button, I hope that the issue is caused by the cam button or maybe my double roller timing chain making contact with cover. I will still measure end play in crank to be sure.
