- Nov 24, 2001
Got the sage green car driving today, been sitting for awhile, started it every month, just couldnt drive it.... had a bad tranny...
At idle stock maf was reading 03 both screens are removed
Installed other stock maf, now reading 05 at idle with one screen. < runs alot better with it.
I would assume, that with both screens removed it would read higher, just wondering... Car would hunt and change rpms with the maf with both screens removed. Will install 1 screen and see how it does...
So i changed chips, spark plugs and installed a brand new heated 02 sensor.
Get this, turn down fuel pressure to 40 psi vac off, 30 with hose on, has msd 50s and 26° race chip NOT a TT chip.... cant wait for the new TT chip...
Anyway, fuel at 40psi hose off, reset ecm for a fresh breath of air... start car and let it idle.
blms at 105 at idle... can you say rich bitch?
Now it threw a code 45 and i didnt have it running but for 5 minutes just to bring the temps back up..
Motor was hot when i did plugs and 02 sensor..
Car doesnt smell rich at all, just cant believe code 45 and low blms that quick.
18" of vacuum...
Cant wait for to get the boost up and dial this sucker in...
Chip program making it so rich?
I tried 3 different "brands"
Or was it the maf with 2 screens removed?
It got too dark out, and i didnt want to piss the neighbors off anymore, single shot tis a lil loud
2 separate issues of was it the maf with 2 screens removed?
None are programmed for missing maf screens.
BW
18" of vacuum...
BW
