Stock timing cover on 3.8 Stage 1 block?
tminer
Not quite normal
Will the stock timing cover work with a Stage 1 block and stock crank?
Would the Stage 1 and steel center mains be a significantly better choice than a stock block, cast mains and girdle? This would be with stock crank.
Any other caveats with stage 1 and stock accessories, motor mounts, etc, besides 14 bolt pan?
tyvm,
Tom
Would be MUCH better than a stock block.
The timing cover needs to be for a 14-bolt pan. All accessories and mounts will bolt on like stock. If the block has the original 2-bolt mains, oiling system is the same as stock.
Turbo drain can be located in the block or the oil pan.
