ok i went to due a boost leak test didnt hear anything leaking except by the butterfly on the throttle body but enough pressure to blow my cup off the turbo lol
when that happened i check the turbo play and it was kinda alot more than usual
its gonna be a bolt on car
what turbo is gonna be a step up bot not break the wallet
60# injestors turbo tweak chip
adj fpr
walbro pump with hot wire
adjustable wastegate
most likely downpipe with the new turbo?
and rjc power plate
the turbo itselve doesnt really hold too much boost when i hit the gas and its spooling at max it takes a while to go from 0 to like 5 ps1 until i got WOT for a sec and goes to 11 its set at right now
but it doesnt build boost to good at all
possible ta45-49? bolt up to stock location with stock cooling and oil lines available
thank you
adj fpr
and rjc power plate
thank you
