Street/Strip 2004r lock up trans with brake and larger servo
brian
Senior Member
As mentioned above.
This is a CZ core, that will shift from 5300-5400 depending on your combo. Speedo gears are set up for 3.42 gearing. It is a lock up trans and is set up to shift quite firm.
The trans has Alto clutches (extra throughout) and wide Red band, 10 vane pump, pump ring kit, larger booster valves. The trans also has a manual "stage right" style brake, and a "case stretcher" servo. All the correct switches and wiring is in place for an easy GN install.
Price is $1450 + shipping. I will accept a BR, BQ, CQ, or CZ core and knock off a few $$$. Please let me know if you have a core, and what model.
Any more questions, please mail me @: hipsibri@cs.com
Feedback can be viewed on my transmissions in the "feedback" section.
Thank you, Brian
I use Yellow Freight. They usually charge $150-$200 for shipping.
The trans on a pallet weighs under 140 lbs.
Thanks, Brian
If it weighs under 150 it could go through Fed Ex or UPS to a business a lot cheaper than that price. I shipped a motorcycle motor from TX to NJ through Fed Ex for $75 and it weighed 145#s. What is your zip and what size box. Also what kind of warranty and how much HP can it handle?
The trans will handle near 600hp, mid-high tens in a full weight car.
Warranty is 6 months against pump or clutch failure.
As for shipping...It is easier to ship Yellow, as I do not have access to crates, or time to build them. If you send me one, we can do that. My zip is 48066.
Thanks, Brian
That depends on which model it is.
I am interested in a CZ or CQ model for my builds.
It may not be worth the cost of shipping to send another version.
Thank you, Brian
The brake is a $150 option. You would not even know it is there, if you do not manually shift the trans to manual low.
I have plenty of cores, and could build you whatever you like.
Thank you,
Brian
