Stretch inter cooler
jim0207
INVNO1
I got this IC back in the 90s. No scope or brackets. Vary well built. Inlet and outlet fit my 87 GN. But, no brackets or scope . So I now going to sell it. I do not fabricate. The passenger side top mounting hole is 2" horizontal from the edge of the core and the cross hair , or vertical measurement is, to the top hole is 3 1/4" down from the top of the core. It has not been pressure tested. First to say I'll take it, takes it. The IC has:
2" inlet and outlet
3 1/2" manifolds
23 tubes at 1/4" thick
Core is 13" wide and 14 3/4" tall
$395.00 OBO
I thought it was a CAS V4 too but it'd have 2.5" in and out if it was. That pass side bracket and the long bolt that goes into the waterpump will be needed but I'm sure it could be fabbed up too. GLWS! Very nice intercooler.
Interested, trying to find a shroud for it.
Does a regular stretch intercooler shroud fit?
Looks just like my cas v4. Except I have 2 1/2 inlets and outlets. Glws
What type of brackets did you use with your intercooler?
The 2-1/2" is on the OD, the ID measures some 2.1", stock measures under 2.1" on the OD and the ID around 1-3/4" I would suspect the 2-1/2" on the OD is correct. Precision is the only slic that I know of with 3" in and out. Hope that helps.
It has no leaks right?
Trying to locate a passenger side bracket and shroud I will respond shortly via pm
I have a shroud as I destroyed my V4.
