My GN was keyed up pretty bad on New Years Eve, and the insurance company cut me a check to fix it, but I can do some of the work myself like disassembly, stripping old paint, things like that and save some $$.
Question is, what should I use for stripping it? I have a DA and good air compressor, would that be the easiest method? What grit should I use? I plan on taking it down to bare metal since the paint that's on there is two layers thick, and has problems.
The plan is to pull the trim, headlights/taillights, bumpers, fillers in a day, and the next strip the car down for the most part, and then take it straight to the body shop so it doesn't sit around in the moisture outside.
Also, after stripping, is there anything I could apply to the sheetmetal to keep it from flash rusting?
Sorry for the long post, just don't want to mess this up.
Thanks for any input,
Jon
Jon
