Stroke motor bottom end clearance
USMC_Turbo6
Is this the proper clearance for a stroker motor with a crank 3.625 and a rod of 5.970? If not I would appreciate it if someone would give me the proper bottom end clearance. Thank you
Bottom end clearances
Main bearing........................ 0025 in
Con rod bearing.................... 0025 in
Con rod side to side.............. 018 in
Piston to wall....................... 004 in
Piston ring eng gap: top ring... 016 in
second ring........................... 014 in
Crankshaft end play.............. 004 in
Here are my thoughts:
Rods/mains......0.0020" - 0.0022"
Rods side..........0.006"
Top ring gap....0.020" depends on ring type?
Piston..........manuf spec, usually 0.005"
I agree with Nick and will add that the second ring gap should be .024" Opening up the second ring gap helps stabalize the ring pack under boost.
Here is what I have for the bottom. Do what I have look right? Thanks for all of your help guys.
Main bearing........................ .0020-.0023 in
Con rod bearing.................... .0020-.0023 in
Con rod side to side.............. .006-.018 in
Piston to wall....................... .045-006 in
Piston ring eng gap: top ring... .018 -.020 in
second ring........................... .024 in
Crankshaft end play.............. .005-.0010
With .006" piston to wall you'll get psiton noise on start up .005" works better. I'd run a bit more ring end gap on the top ring myself. Rod side clearance will sort be what it is but .010" works well I wouldn't want much less. Stock rods usually have quite a bit more closer to the .018 you stated which works fine too.
Neal
