Stroker rebuild need to update xfi
psycho6cyl
Ponies Are For Lil Girls
Before I had a chance to hook.up xfi I had to send my motor.out.for.a.rebuild..Some things have changed,possibly cr,cubic.inches and cam. Everything else turbo inj etc stayed. I remember filling out these questions on the xfi order sheet. Does it have to be adjusted? I would think not.
If the cubic inches have changed a little (bored engine) then just change the displacement in the fuel calc parameters table. If it has changed a lot (stroker crank) then you will need to do more than just change the displacement.
Ok thx cal. Should that be done before first start up/break in motor? Or can that be done after? Something we can do.over phone when.I call for first start up? Thx
Just remind me when we do the first startup and I will walk you through the changes.
