While swapping out my ARP bolts for studs I noticed that the longer studs in center came up a tad short on my gn1's. This was with the studs finger tight,just starting to bottom. with washer and nut i could use about 3/16 more length to get 100% bearing in nut. The stud length is 5.0 in. Part #223-4204.
?-Do they NEED to bottom out in the block?
I'm thinking I'll just bring the heads into the shop and spot a bit deeper. I also am not to happy with the spot face dia,it could be a slightly larger dia. Tommorow I will check the dia.
?- Any one know how much meat is under the head?
? can I order 4-5.25 long studs from ARP?
Mart
Mart
