Studs for RJC power plate install
TURBOV6
"SECRET PARTS"
Staff member
I heard of guys using studs for the ease of the installation and also stripping the threads on the bolts for the plenum. Anyone know what the thread size and length of the studs?
The install was pretty easy just using the stock hardware. As long as you tighten the bolts by feel instead of by the torque-specs. It only took about 25 minutes.
Since the PP is 1/8", how about 1/8" longer than stock? The stock set-up is 3 bolts and 2 studs. The bolts are 25 mm long. The studs - dunno. Maybe it doesn't matter if you only intend to change the bolts for studs.
BTW, you can overtighten a stud and nut combination too, so is it any better? Either way the threads can pull out...
