If you never checked a front end before.Take the car to a midas or shop like that that gives free estimates and most of the time they bring you out and show you what is bad. get the estimate and post what they say.They might overllook the upper control arm bushings.If you want my advice replace it all.They have complete kits on line if money is an issue. I watched evil bay and found all moog parts cheap. rock auto is pretty cheap also.I went with global west del a lum bushings.anyways front end jobs can get real expensive unless you do it yourself.The last one I did was I think $600.00 and the guy brought his own parts.I changed everything bushings,springs, shocks.all steering parts. sway bar bushings and links.If you have someone do it watch overlap on labor times shops will charge labor for every part I have seen 13 hour estimates not including the alignment.be careful with that.I think 8 hours is about what it should be. good luck
