- Dec 15, 2002
Chasing a tip in issue, swapped TPS and lost the ability to set the volts, got -00 on Scanmaster. ECUGN shows TPS Fault and for some reason Scanmaster says Code 5.
ECU-IGN fuse is good, I'm getting 5V at the plug, I have alky but can't recall if that taps into the middle TPS data wire.
What helped fix yours?
Picture is of new Ac Delco tps and volt meter.
BTW, new Delco sensor 184 didn't have the logo on it.
Mike
Mike
