Apr 20, 2006 #1 S slowGN Member Joined May 25, 2001 Messages 104 hello anyone know the sweet spot for one of Cottons 65 turbos. I had the boost up to 23 this weekend and it did not pull any harder than the te44 I had on there running 21. Thanks CJ
Apr 20, 2006 #2 S Sweet6 Well-Known Member Joined Jun 12, 2001 Messages 3,547 If it is a stock motored car, figure 25lbs+. I'd guess 25-27lbs.
Apr 20, 2006 #3 Pronto No amount of evidence will ever persuade an idiot. Joined Dec 9, 2002 Messages 16,818 Wouldn't it make more sense to talk to Jack to see what your need to do with whatever mods you have to run that turbo?
Apr 24, 2006 #4 1 19TTA89 I know 8sec Pete!!! Joined Feb 18, 2002 Messages 970 With a set of GN1's and the cpt65....55lb injectors. 11.60@116...19 lbs of boost 94 octane only Never turned it up,Because of no rollbar,And It was fast enough for me on 94 octane.But I felt It would of been a solid 10 sec car with 26lbs or so.
Apr 24, 2006 #5 D disco stu Active Member Joined Apr 10, 2002 Messages 2,562 I ran 10.70/80's at 25 psi on iron heads with one Spooled stupidly fast. Faster than stock. I had a 3000 convertor. I could have used the stock one.
