After switching to 72s the car starts rather well, idles "ok" with only a little hunting, cruising is about the same as before, start-off and gear changes are plenty jerky but can keep her going.
Problem is that most of the above is happening with 15.94 AFRs or at least on the high end of 14+. Idle VEs are 78 and it takes 90 in those cells to get the reading down from the 15.94. When I set closed loop, seeing 20-24% correction at highway cruise.
The only thing I changed was the Fuel Calc to show 72's. I verified that the #3145 SiemanDeka were in fact '72s. I also switched sides for the 02 sensor to rule out a bad injector - both sides acted the same. Car was fully warm for all this. The 36# tune wasnt perfect, but did fine for driveablity yesterday.
So, first, is it really possible for my car to to have behaved as good as it did (albeit pretty jerky) with such a lean reading?
And second, what should I look at first before making my VE tables all 90 and up for the cruise/idle cells?
Thanks for any thoughts on this.
